dual antennas???
chopcorejc
dual antennas???
#34481
Post by chopcorejc »
do dual antennas make that much of a difference, or is a single antenna fine??????????i have a big truck and would be able to mount one on each mirror, but don't know if it's really worth it.....
Phaze91460
#34483
Post by Phaze91460 »
Better to mount a single antenna on the passenger side for use. you could mount another on the drivers side for looks. This gives you more forward and left TX. Duel antennas tend to blank out each other a little bit and wont TX RX as well.
THUMPER
#34484
Post by THUMPER »
YA WHAT HE SAID
dozerpilot
#34499
Post by dozerpilot »
Bigger is better, but less is more! :D
Mr RadioActive
#34552
Post by Mr RadioActive »
I kinda say go with the drivers side, only because oncoming traffics always going to be on that side. And with the right ground plane, you'll be bouncing signals like a rubber ball!
I would also recomend just one single antenna. Alot less headach's, and easyer to tune.
I also would say go with the driver's side, due to tree limbs that generaly tear-up antennas mounted on the passenger's side. Plus, on the Drivers side, your signel is going to be directed more towards on-comeing traffic.
Mounted on the passenger side, signels going to be directed to the tree's! :lol: Dont think there going to be giveing you any bear reports! :shock:
chopcorejc
#34589
alright, a single on the driver side it is.............thanks everyone.......
Roadrunner
#36765
Post by Roadrunner »
I agree that it's easier & cheaper to run a single antenna. BUT... There is a very good reason to run dual antennas! (Other than just looks.) If the dual antennas are matched & co-phased correctly, you will get a larger & more even radiation pattern than with a single antenna. The reason it's not very effective or practical for most vehicles is because the antenna separation needs to be around 9ft. to work properly.
8)
#36776
Post by 231 »
Roadrunner wrote:I agree that it's easier & cheaper to run a single antenna. BUT... There is a very good reason to run dual antennas! (Other than just looks.) If the dual antennas are matched & co-phased correctly, you will get a larger & more even radiation pattern than with a single antenna. The reason it's not very effective or practical for most vehicles is because the antenna separation needs to be around 9ft. to work properly.
8)
This is correct. If the spacing isn't correct it can in fact cause signal reduction. It's not easy to properly co-phase a system for maximum efficiency and minimum SWR. However, when properly set up they work about (guestimating) around 15% better than a single antenna system. In most cases, hardly worth it IMO.
rattlesnake
Real Name: chris
Radio: cobra 29 nw classic
#292401
Post by rattlesnake »
1 antenna is all u need with 2 antennas u will go in differnt directions
Radio 75
#292451
Post by Radio 75 »
Are you set on a mirror mount? If not, I would highly recommend mounting it on the cab roof in the center, much more omnidirectional.
Worster
Handle: MisterWorster
Real Name: Patrick
Antenna: Wilson 2000
Radio: 2 tin cans a string
Post by Worster »
My own experience, on a semi truck mirror mount dual is better, less directional, but complicated i am fortunate enough mine worked out well for me without complications, i have my co phase harness and a single phase coax run for back up incase i rip the passengers side antenna off where i work in the woods, which has happend so thats where i have noticed the difference, if you dont mind taking the time and doing it right you will see a difference, OR you can do whats stated above and just mount one in the center of your cab and get the same results as a dual and be done with it once you get your SWR's proper, with me i cant mount on my cab due to company UHF/VHF radios proximity
My Bare feet:
Magnum S-6 Tuned by Clays Radio Shop Road King 56 (Sold)
Connex 4600 Turbo, Clays Radio Shop Road King 56 (Sold)
Connex 3400 HP, Sparkys CB Shack, Astatic 636L
2 Single Coil Predator 10K 12 inch shafts
"I'm Just a Matchbox Car playing in a Tonka Truck World"
Worster
Real Name: Patrick
Post by Worster »
I forgot to add, i wouldnt go any closer than 8' 6"(102") 9' would be ideal
My Bare feet:
DanTaylor
Real Name: Jason
Radio: Galaxy 959
Post by DanTaylor »
Curse you guys for you know being knowledgeable!!! I am debating putting a radio in my pickup truck and honestly had NO clue that it can be better to run a single antenna. Glad to have found this site for sure.
WORK TRUCK Galaxy 959 peaked and tweaked with echo
PLAY TRUCK Cobra 29 NWST peaked and tweaked
BASE Uniden Washington with a swing kit and a D-104
drdx
Handle: dollar-98
Real Name: David
Antenna: Many
Radio: Many-
Post by drdx »
This topic/thread is 4 years old, wow. Read up on the dual antenna deal. Given the right situation, it can be of benefit. It does take more setup, space, thought, and time but sometimes it is worth it. Every mobile antenna system is directional to some degree, as none will have a clear pattern. I'd think that a semi would have among the worst patterns. They're really long and the antenna is usually on the side at one end. In theory, the signal from an antenna on a driver's mirror would radiate the strongest to the right rear of the trailer, because that's where the metal is. Some claim that the dual deal cleans up that pattern if done right but many things have to be right and many things, like the vertical exhaust, also effect the signal. That said, I'm a single antenna fan just out of simplicity and success.
