ANTRON 99
- rattlesnake
- Real Name: chris
- Radio: cobra 29 nw classic
ANTRON 99
I want to get an antron 99 how can i mount this is there a easy way like get steel pipe and put them in the ground like the pipes 10 or 15ft tall and put the antenna on top of the pipe..Will that work..Or fencing.
- HomerBB
- Handle: Homer, 2WR183, Country Preacher
- Real Name: Charles
- Call Sign: K5HBB
- Radio: IC-746
It will work. Many people use the Antron99 in just that way. In fact, in years passed when I traveled in an RV I used exactly that setup for my station switching off from a mobile antenna when I parked to the A99 on a 20' push-up pole. However, it is best to get it as high as you can. I suggest that you use a choke made of 5 -6 wraps of your coax around a 4" piece of PVC ( a PVC coupler works well) just beneath the feedpoint of your antenna (that is, where the coax fastens to your A99). Get hooked up and have fun.
It's Not Crazy, If It Works
The 11 Meters MacGyver
- rattlesnake
- Real Name: chris
- Ronin
- Handle: Ronin or 921
- Real Name: Jim
- Antenna: Imax
- Radio: Pro-810e, 139XLR 142GTL
Yep...Do exactly as HomerBB had said and you it will do a nice job for you. I ran an A-99 for about 15 years and the only minor issue they sometimes have (unless they have improved this over the years) is that the coating over the fibreglass can wear off due to weather. I took mine down at about 7 years and again a couple years later and sprayed a few coats of Krylon paint on it. I have heard that there is a spray paint for fibreglass boats that works even better and probably lasts longer too. I suspect that this could happen to any of the fibreglass antennas. I have an Imax up about 4 years now.... so I guess I'll see in a few years.
