Maco 103 how high
superman 438
Real Name: ABEAR
Maco 103 how high
#285393
Post by superman 438 »
How high should i put my maco 103 can you put to high and not get out and hear good.
PA629
#285394
Post by PA629 »
General consensus is the higher the better. One wavelength (aprox. 36 ft.) to the boom will be fine, and is the usual benchmark people shoot for. Above that is better still.
#285398
Contrary to popular belief, you can definitely get an antenna 'too high'! You typically know that happens when the feed line won't reach the antenna. The common 'cure' is to extend the length of the feed line. Then, the antenna is no longer 'too high'.
PA629
#285404
Post by PA629 »
'Doc wrote:Contrary to popular belief, you can definitely get an antenna 'too high'! You typically know that happens when the feed line won't reach the antenna. The common 'cure' is to extend the length of the feed line. Then, the antenna is no longer 'too high'.
Hey Doc-
I need one of those feed line extenders, the CB Shop at the local Pilot doesn't carry them. Who makes a good one? :icon_rolleyes:
superman 438
Real Name: ABEAR
#285489
Thank you for the help and DOC that was funny thank i needed that. :lol:
420Snowman
#285685
Post by 420Snowman »
When you have to put a light becon at the top, you might be a little too high!!!
Snowman
Slim Pickins
Handle: Slim Pickins
Real Name: Paul
Call Sign: VE1PEW
Radio: Realistic Navajo 457
Post by Slim Pickins »
420Snowman wrote:When you have to put a light becon at the top, you might be a little too high!!!
Snowman
Why not just put the light on it and then it won't be too high anymore :biggrin:
73,Slim
420Snowman
#285883
Totally Slim!!!! Thats what I would do!!!
Snowman
#285891
Light beacons.
Aside from just the paper work, have you ever seen the price of the beacons you have to use on a tower that high? You definitely want to be sitting down when you do! :)
PA629
#285937
Post by PA629 »
'Doc wrote:Light beacons.
Nuthin' to it. Just hook up a bunch o' LED's to a wall wart.................ten fer? :icon_rolleyes:
#285940
As a matter of fact...
There are LED beacons available now! Not exactly what you find at Radio Shack, and no wall-wart powers them, but dang sure LEDS. You'd still better sit down.
