RADIO SHACK PRO70
Fast4socal
Real Name: Jason
Antenna: 10k
Radio: Magnum s9
RADIO SHACK PRO70
#259020
Post by Fast4socal »
im having some issues with it i added alll the frequency's there is here in town and ....it is locked out when i turn it on all it does is scan it wont let me turn on the light or go to WX i tried a soft reset there is a little hole on the side that does a soft reset but it still wont unlock it when its on it says scannning and i hear talking but on the right corner there is a little key on the screen i cant press anything to unlock it ....what do i do? can i take it apart and reset it? hard reset? radio works great but id like to be able to listen to weather too :bounce: :aaargh:
"there are only ten types of people in this world, those who understand binary and those who don't"
RCi 2950 base
s9
Fast4socal
Real Name: Jason
Antenna: 10k
Radio: Magnum s9
BUMP
RCi 2950 base
s9
#259129
When all else fails, RTFM.
Fast4socal
Real Name: Jason
Antenna: 10k
Radio: Magnum s9
'Doc wrote:When all else fails, RTFM.
RTFM? Read The **Censored** Manual ? i have no manual bro and its old and it worked great one day untill i pressed lock and now its locked on like the button got stuck,,? im just gunna take it apart! maby there is something loose on the keypad
RCi 2950 base
s9
Sporty Mike
Real Name: Michael
Antenna: S.S. 102 / Maco V5/8
Radio: Alot of 'em!!
Post by Sporty Mike »
If that dosen't work, use it to take out pent up aggression, aka, baseball bat, golf club, driving over it....use your imagination.
Sympathetic,
Mike
#259186
**Censored** ? Why, no. That 'F' stands for 'furnished'. Doesn't it? :)
'Google it.
Fast4socal
Real Name: Jason
Antenna: 10k
Radio: Magnum s9
ha! i did goggle it !!
RCi 2950 base
s9
#259260
Try here;
Fast4socal
Real Name: Jason
Antenna: 10k
Radio: Magnum s9
okay what im trying to tell you is this : Key Lock — lets you lock the scanner’s keys to help prevent
accidentally changing the scanner’s programming. key lock is stuck and i thought maby addressing it here might be able to get some help on unlocking it but i might do as sporty mike said and use my imagination on destroying a good piece of equipment.
RCi 2950 base
s9
Fast4socal
Real Name: Jason
Antenna: 10k
Radio: Magnum s9
well i took it apart and noticed two square boxes on the circut board so iturned one the squelch went longer the other is volume broke that one but thats okay its as loud as its gunna get so i get really mad took a skrew driver and stabbed the keylock button and held it it finnaly unlocked. woohoo works now.
RCi 2950 base
s9
Sporty Mike
Real Name: Michael
See, sometimes anger does pay off. 8)
Mike
Fast4socal
Real Name: Jason
Antenna: 10k
Radio: Magnum s9
anyone got any ideas on a homebrew antenna for this thing rat shack charges 20 bucks for a 800mhz antenna <--dont need it. i bought a adapter that makes the scanner hook up to a cb coax but id rather use my own wire or something i guess ill cut the antenna that is on it and solder my own wire. and yes anger does payoff sometimes if done right. lol
RCi 2950 base
s9
#259500
With UHF, higher is always going to produce more signal than almost anything else. UHF is 'line of sight'. Signal strength isn't as important as the two antennas 'seeing' each other (which doesn't say that signal strength isn't important).
If an antenna for a lower frequency is harmonically related to the desired frequency, it'll work. I sort of doubt I'd cut down an existing usable antenna to make it unusable for it's intended band unless I knew I would never be interested in that band again.
One method for a multipurpose antenna is to use 'stingers' cut for the desired band and connecting them all to the same feed point.
I really think that if I wanted a really multi-band antenna for VHF/UHF I'd check into a 'Disk-Cone' type thingy. They do work. And being naturally cheap, I'd make one before buying one, they aren't that difficult, sort of.
Fast4socal
Real Name: Jason
Antenna: 10k
Radio: Magnum s9
'Doc wrote:With UHF, higher is always going to produce more signal than almost anything else. UHF is 'line of sight'. Signal strength isn't as important as the two antennas 'seeing' each other (which doesn't say that signal strength isn't important).
do u mean a biconical antenna ?
RCi 2950 base
s9
#259532
No, a "disk-cone" antenna. There's a difference.
Fast4socal
Real Name: Jason
Antenna: 10k
Radio: Magnum s9
'Doc wrote:No, a "disk-cone" antenna. There's a difference.
show me a pic of one please. i cant find a schematic or picture of one.
RCi 2950 base
s9
#259661
Google "disk-cone antenna". You'll get several hits, one of them is bound to have a picture and how to build one.
