swr s and moving antenna
fester
#23688
Post by fester »
I have an 04 grand cherokee, running a wilson 5k mag. saving money for a SWP general lee. my job takes me into parking garages and other low clearance areas requiring me to remove my antenna for a little bit. once i set my swr's does the moving it like that change them enough to be concerned about.
thanks,
roadhazzard
RabidRobert
#23691
Post by RabidRobert »
I run a Wilson 1000 mag & have to do the same thing at times, and I haven't had a problem with it. I have done it both ways, unscrewing the coil & the removing the entire thing to wash the truck & all. It shouldn't change the SWRs as long as you put it in the same position as was when SWRs checked good. Moving it to a different location could change it.
8)
Guest
#23693
Post by Guest »
RabidRobert wrote:I run a Wilson 1000 mag & have to do the same thing at times, and I haven't had a problem with it. I have done it both ways, unscrewing the coil & the removing the entire thing to wash the truck & all. It shouldn't change the SWRs as long as you put it in the same position as was when SWRs checked good. Moving it to a different location could change it.
8)
Yeah what he said
BobOstro61
#23703
Post by BobOstro61 »
:06-28iag: :06-28iag:
SmallTruckBigRadio
#23774
Post by SmallTruckBigRadio »
I would agree too, but wouldn't that get repetitious?
I will say...keep it clean, and waxed a bit too.
Oh, and welcome to the CB Radio Talk Forum...
Phaze91460
#23776
Post by Phaze91460 »
How did I miss that ?
Well, Greetings ! and welcome to the forum from sunny Georgia !
fester
#23801
Post by fester »
Thankya, thankya very much. i grew up using the radio as a kid but never learned much about them on the technical side of things.
R
fester
#23802
Post by fester »
R
Phaze91460
#23836
Well, you have now found the place to learn whatever you want, chat, find friends, etc. I have found this a good place to be. And I have learned a lot since I've been here.
stickman
#23865
Post by stickman »
fester wrote:I have an 04 grand cherokee, running a wilson 5k mag. saving money for a SWP general lee. my job takes me into parking garages and other low clearance areas requiring me to remove my antenna for a little bit. once i set my swr's does the moving it like that change them enough to be concerned about.
thanks,
roadhazzard
FIRST OFF LET ME SAY WELCOME TO THE FORUM!!! I RUN A WILSON 1000 ON MY 05 DAKOTA AND I MOVE MINE TO RUN THROUGH THE CAR WASH ALSO GOING INTO A GARAGE AND I HAVE HAD NO PROBLEMS WITH MY SWR'S. JUST LIFT THE MAG MOUNT AND LAY IT IN THE BED OF THE TRUCK AND THEN WHEN I AM DONE PUT IT BACK ON TOP. YOU SHOULD BE FINE!!!
STICKMAN
Working Cowboy
#24394
Post by Working Cowboy »
Welcome and as been stated so well you found the right place.
