lighting and antennas
- Tinman590
- Real Name: Andy
- Radio: Icom and RCI-2980
Re: lighting and antennas
ELKIN 6 (6dq6) sometimes a driver
Henry Radio 2k2
Imax 2000
4 element maco
RCI-2950 twin tube modulator
Cobra 2000
Washington
A bunch of other stuff
Re:
Post by 127 »
Texas Mobil 219 wrote:Say hacksaw. Glass will prevent the electricity from bouncing all over the inside for your car or truck. That is if your the luck one to get hit. Ive seen what it can do to a amp and a cb. Pretty my melted them together and blow the batteries. Wasn't a pretty site to see 2000 bucks down the drain.
I don't think a glass jar will contain the 1.21 giggawatts potential of lightning.
Post by Century21 »
Post by DuckSoupe »
- Radio: GOLDEN EAGLE Mark IV
Post by PONY EXPRESS »
DuckSoupe wrote:Folks I had an antron 99 on my roof and the thunder rolled in. I tool the coax from behind the radio and was going to flip it out the window when the coax got hot. There was a crack when the antenna got hit and a stream of white light cameout of the coax. everything in the room including my computer was fried. The antenna was shredded to pieces. every hair on my body was positivly charges and I went to the hospital where they grounded me and my hair went down.I hope you never have that happen to you. This is a true tale
Did you all take notice THERE IS AN AWEFUL LOT OF ANTRON 99s getting hit by Lightning
Post by linx »
Wait a sec. You had to go to the hospital where you were grounded? Is it April fools?DuckSoupe wrote:Folks I had an antron 99 on my roof and the thunder rolled in. I tool the coax from behind the radio and was going to flip it out the window when the coax got hot. There was a crack when the antenna got hit and a stream of white light cameout of the coax. everything in the room including my computer was fried. The antenna was shredded to pieces. every hair on my body was positivly charges and I went to the hospital where they grounded me and my hair went down.I hope you never have that happen to you. This is a true tale
Post by DuckSoupe »
Absolutly the truth. My body was charged. Ask a doctor. I lost a computer and scanner. My cb base was unharmed, figure that outlinx wrote:Wait a sec. You had to go to the hospital where you were grounded? Is it April fools?DuckSoupe wrote:Folks I had an antron 99 on my roof and the thunder rolled in. I tool the coax from behind the radio and was going to flip it out the window when the coax got hot. There was a crack when the antenna got hit and a stream of white light cameout of the coax. everything in the room including my computer was fried. The antenna was shredded to pieces. every hair on my body was positivly charges and I went to the hospital where they grounded me and my hair went down.I hope you never have that happen to you. This is a true tale
- Red Warrior
- Radio: Galaxy 959
Post by Red Warrior »
Lynx,linx wrote:Wait a sec. You had to go to the hospital where you were grounded? Is it April fools?DuckSoupe wrote:Folks I had an antron 99 on my roof and the thunder rolled in. I tool the coax from behind the radio and was going to flip it out the window when the coax got hot. There was a crack when the antenna got hit and a stream of white light cameout of the coax. everything in the room including my computer was fried. The antenna was shredded to pieces. every hair on my body was positivly charges and I went to the hospital where they grounded me and my hair went down.I hope you never have that happen to you. This is a true tale
The human body can act like a capacitor. For instance when you drag your shoes across a rug in the winter. The static charge is quite substantial but builds on the surface of the body rather than inside. Faraday put it this way:
"Faraday established that static charge resides on the outside surface of a conductor. This also applies to partial conductors like the human body and because of mutual repulsion and mobility the charge will be distributed on the body so that its density is proportional to the body curvature. In searching for a basis on which to calculate capacitance we note that a sphere of radius about 0.8 m is a reasonable first approximation to describe the location of charge. If we use this sphere as a model then electric fields a few metres from the body will be accurately described. Close to the body the charge clusters at extremities of the body and the totalcapacitance will tend to be less than that of the proposed spherical model."
The resulting static charge will be completely discharged with the first proximity opportunity to ground (including another person). The probability of carrying a charge all the way to a hospital is minute.
- Twink
- Real Name: Reno
- Radio: Cobra148F/Cobra 200
- Texas Mobil 219
- Radio: Uniden 78
Post by Texas Mobil 219 »
CB = Continuiosly Breaking.
or Continuiosly Buying.
LOUD PIPES SAVE LIVES
Send your signal to the world
- Handle: LWD
- Real Name: John
- Radio: Cobra 29, Galaxy 959
There is a much greater chance during a storm for static buildup in your antenna to cause damage than for a direct hit to occur at all.
Post by 909WiSCoNSiN »
I heard rumors about the glass jar. you know I think I would rather be struck by lightning itself than to be struck by lighning and glass!
- Real Name: Troy Lucas
- Radio: Cherokee CBS-1000
TRC 242
TRC 454 (FUN FUN) (8) Ring ring ring BANNANA phone (8)
Uniden 68XL
K-40
Home made ground plane
Post by 420Snowman »
Snowman
- IdahoPete
- Radio: Galaxy DX 2517
420Snowman wrote:Well, what happens if your antenna is NOT grounded, does the charge run straight back through the coax and burn the roof, siding, drywall, and whatever is in its path??? And if the antenna IS grounded, does the charge choose to go down the copper wire to the ground rod RATHER than going down the coax?? Electricity takes the path of least resistance, correct??
Snowman
YES and yes to all. I live it south Idaho with many t storms here it the valley. I ground everything!
Owner/Operator: IPAdventures.net
Keep your head low and your powder dry!
Post by 721HACKSAW »
- IdahoPete
721HACKSAW wrote:There is no way to predict the path of lightning, it can make anything a conductor, trees, poles, houses, ect... JSM201 was right on the money in his post, the electrical charge in the air doesn't have to be at lightning strength to cause damage in electrical components, ground your equipment properly. If possible unplug your coax and your incoming power before a storm. Update your insurance policy, they need to know you have the equipment before you try to make a claim.
Good feedback! Just make every precaution. Then pray!
Then I heard a hell of a storm outside. Got up and went to turn on the lights and had no power. Lightning hit the power line coming in the house, not a 40 foot tower in the yard , and smoked everything plugged in the outlets, ( tv, computers, amp, stereo, and worst of all, my coffee pot).
Luckily my homeowners insurance paid for most of my junk.
- 12 gage
- Real Name: Patrick
- Welcome and Community
- Skip Shooter's Paradise
- ↳ General Discussions
- ↳ Watergates & Videogates
- ↳ Shooting Skip
- ↳ Hall Of Fame
- ↳ Journal
- Radio Help
- ↳ Intro To Radios 101
- ↳ General Questions
- ↳ Base Setups
- ↳ Competition Rigs
- ↳ Charging System
- ↳ Mobile Setups
- ↳ Antenna Help
- ↳ Microphone Info
- ↳ Radio Modifications
- ↳ Sideband (SSB)
- ↳ Tube Radio Equipment
- ↳ Other Technical Questions
- ↳ Miscellaneous Radio
- Buy / Sell / Trade
- ↳ For Sale Area Rules
- ↳ For Sale Area
- ↳ eBay Shopping
- ↳ Amazon Shopping
- ↳ Trade Equipment
- ↳ Wanted Radio Equipment
- ↳ Positive Feedback
- Off Topic
- ↳ Miscellaneous Chat
- ↳ Computer Help
- ↳ Signature Test Area
- The White House
- ↳ Ask Marv
- Home
- All times are UTC-06:00
- Cookie-Settings
- Delete cookies
- About us
- Downloads
- Contact us
