Help With Choosing New Base Antenna
redneck330
Real Name: Ronnie
Antenna: Wilson 5000
Radio: Galaxy 88 HL
#237463
Post by redneck330 »
I am looking to buy a new base antenna. Comments? Suggestions? I'm looking to get the most for my money.
330 - Mr. Redneck in the Coal Country of Virginia
#237464
What'cha got now?
redneck330
Real Name: Ronnie
Radio: Galaxy 88 HL
An old Maco. I plan to keep it in the air but wanting another to place in a different spot on the mountain behind my house.
#237476
Post by 231 »
redneck330 wrote:An old Maco. I plan to keep it in the air but wanting another to place in a different spot on the mountain behind my house.
How much coax do you need to run to get to the antenna on the mountain? Heck, you might want to consider using the one you have and invest in some good quality low loss coax if it's a long distance. A guy I know had about 400' of coax to get on the top of a little hill behind him (the hill is about 300'). He threw up an Imax2000 on a 20' mast and as far as I know it's now the only antenna he uses. But the coax cost him quite a bit...but was worth it for him.
Just a thought.
:icon_e_wink:
redneck330
Real Name: Ronnie
Radio: Galaxy 88 HL
The Maco is only about 50 feet behind the house. It works really well but I want to get a little more altitude to get out a little better.
#237479
Can you make a guess as to how far this new antenna would be from your house? The reason I ask is that if the distance is very much, there are alternatives to using coax as the feed line. Two of the reasons for doing so is quite a bit less loss, and quite a bit less cost. It's not all that simple though, and if the run isn't a very long one, probably isn't a solution for everyone.
redneck330
Real Name: Ronnie
Radio: Galaxy 88 HL
Probably no more than 250-300 feet.
redneck330
Real Name: Ronnie
Radio: Galaxy 88 HL
bump
