good place(other than mirror arm)to mount vertical antenna
[byuslim09]
Handle: Bayou slim
Real Name: david jeanpierre
Antenna: Rush hour
Radio: swp/srx general lee
#236164
Post by [byuslim09] »
Hello everyone,I have a rushour made vertical ordered and will have it by the end of the month.was looking for some suggestions on mounting locations other than the mirror arms to mount it on my 07' international 9200I that will give me optimum performance from this vertical.helpful comments are greatly appreciated :biggrin:
"Stand for something or fall for anything is what my uncle always told me"........but he always said it as he was picking himself up off the ground!!!!
Hazelnut 7201
Handle: hazelnut
Real Name: Kerry
Radio: General Lee
Post by Hazelnut 7201 »
Do you have a bar behind the cab that supports the air lines?
I have also seen antenna's mounted on the cross brace on the cab extensions.
Have a nice day.
Hazelnut
#236200
Any place that will allow an antenna to be mounted a 'reasonable' distance from metal, meaning clear of the rest of the body, that is strong enough to support the antenna and mount, and that isn't obstructing stuff, ought'a work okay.
That could range from the front bumper to the top of the cab just depending on the antenna. You are a lot more familiar with your truck than I am, so where -could- you put an antenna?
[byuslim09]
Handle: Bayou slim
Antenna: Rush hour
Hazelnut 7201 wrote:Do you have a bar behind the cab that supports the air lines?
there is a bar behind the cab but it sits down low and my coil will be way too close to the back of the sleeper
:cry:
North Texas Mudduck
Post by North Texas Mudduck »
:cry:
what the distance from the bar to the top of the cab?
[byuslim09]
Handle: Bayou slim
Antenna: Rush hour
:cry:
About four feet
North Texas Mudduck
better post a pic of that bar to see what kind of idea i can come up with
[byuslim09]
Handle: Bayou slim
Antenna: Rush hour
North Texas Mudduck wrote:better post a pic of that bar to see what kind of idea i can come up with
how do you add an image? I tapped add image and it said uploads disabled? ????
Hazelnut 7201
Handle: hazelnut
Real Name: Kerry
Radio: General Lee
Do you have an airdeflector on top of the cab or is it a flattop? :?:
There is usually metal braces/supports on an air deflector that could support an antenna. :idea:
Another idea would be to fabricate a bracket that would bolt between the hose hanging bar and the back of the sleeper. That bar will just shake if you put a 4' extension on it for an antenna. The bracket should run straight up and hopefully you can find a place to put a bolt in at the top.
Have a nice day.
Hazelnut
[byuslim09]
Handle: Bayou slim
Antenna: Rush hour
Hazelnut 7201 wrote:Do you have an airdeflector on top of the cab or is it a flattop? :?:
my truck is a midroof truck without an air deflector.
#236288
How tall is that antenna?
[byuslim09]
Handle: Bayou slim
Antenna: Rush hour
'Doc wrote:How tall is that antenna?
the antenna is six feet tall doc.
#236362
I have doubts about the six foot thing being short enough to mount on the cab roof and not getting 'clipped' by bridges etc. But, if you think it'd clear them, that's where I'd put it. 'Course, that depends on the cab being metal and so on. (If I had a dime for everything I don't know about trucks, I'd be rich!)
[byuslim09]
Handle: Bayou slim
Antenna: Rush hour
'Doc wrote:I have doubts about the six foot thing being short enough to mount on the cab roof and not getting 'clipped' by bridges etc. But, if you think it'd clear them, that's where I'd put it. 'Course, that depends on the cab being metal and so on. (If I had a dime for everything I don't know about trucks, I'd be rich!)
you are hilarious doc
:aaargh: I'm gonna try to mount it to the bumper and if no success there I'll settle for the mirror arm.
Hazelnut 7201
Handle: hazelnut
Real Name: Kerry
Radio: General Lee
Doc is right about the 6' on top of the cab hitting bridges.
I drive a '06 IH daycab 9200 and anything over 65" starts to hit things.
How about those brackets designed to hold load bars? Can something like that be adapted for an antenna mount? Too bad you don't pull a flatbed and have one of those giant "headache racks".
Have a nice day.
Hazelnut
[byuslim09]
Handle: Bayou slim
Antenna: Rush hour
Hazelnut 7201 wrote:Doc is right about the 6' on top of the cab hitting bridges.
Good point hazel nut, I will stick with the mirror arm, appreciate all the help and ideas from the good time gang. ...bayou slim readn' the mail
How about those brackets designed to hold load bars? Can something like that be adapte :cheers: d for an antenna mount? Too bad you don't pull a flatbed and have one of those giant "headache racks".
