good place(other than mirror arm)to mount vertical antenna
- [byuslim09]
- Handle: Bayou slim
- Real Name: david jeanpierre
- Antenna: Rush hour
- Radio: swp/srx general lee
Hello everyone,I have a rushour made vertical ordered and will have it by the end of the month.was looking for some suggestions on mounting locations other than the mirror arms to mount it on my 07' international 9200I that will give me optimum performance from this vertical.helpful comments are greatly appreciated
"Stand for something or fall for anything is what my uncle always told me"........but he always said it as he was picking himself up off the ground!!!!
- Hazelnut 7201
- Handle: hazelnut
- Real Name: Kerry
- Radio: General Lee
Do you have a bar behind the cab that supports the air lines?
I have also seen antenna's mounted on the cross brace on the cab extensions.
Have a nice day.
Hazelnut
Hazelnut
Any place that will allow an antenna to be mounted a 'reasonable' distance from metal, meaning clear of the rest of the body, that is strong enough to support the antenna and mount, and that isn't obstructing stuff, ought'a work okay.
That could range from the front bumper to the top of the cab just depending on the antenna. You are a lot more familiar with your truck than I am, so where -could- you put an antenna?
- [byuslim09]
there is a bar behind the cab but it sits down low and my coil will be way too close to the back of the sleeperHazelnut 7201 wrote:Do you have a bar behind the cab that supports the air lines?
- North Texas Mudduck
what the distance from the bar to the top of the cab?[byuslim09] wrote:there is a bar behind the cab but it sits down low and my coil will be way too close to the back of the sleeperHazelnut 7201 wrote:Do you have a bar behind the cab that supports the air lines?
- [byuslim09]
About four feetNorth Texas Mudduck wrote:what the distance from the bar to the top of the cab?[byuslim09] wrote:there is a bar behind the cab but it sits down low and my coil will be way too close to the back of the sleeperHazelnut 7201 wrote:Do you have a bar behind the cab that supports the air lines?
better post a pic of that bar to see what kind of idea i can come up with
- [byuslim09]
how do you add an image? I tapped add image and it said uploads disabled? ????North Texas Mudduck wrote:better post a pic of that bar to see what kind of idea i can come up with
- Hazelnut 7201
- Handle: hazelnut
- Real Name: Kerry
Do you have an airdeflector on top of the cab or is it a flattop?
There is usually metal braces/supports on an air deflector that could support an antenna.
Another idea would be to fabricate a bracket that would bolt between the hose hanging bar and the back of the sleeper. That bar will just shake if you put a 4' extension on it for an antenna. The bracket should run straight up and hopefully you can find a place to put a bolt in at the top.
Have a nice day.
Hazelnut
Hazelnut
- [byuslim09]
my truck is a midroof truck without an air deflector.Hazelnut 7201 wrote:Do you have an airdeflector on top of the cab or is it a flattop?![]()
How tall is that antenna?
- [byuslim09]
the antenna is six feet tall doc.'Doc wrote:How tall is that antenna?
I have doubts about the six foot thing being short enough to mount on the cab roof and not getting 'clipped' by bridges etc. But, if you think it'd clear them, that's where I'd put it. 'Course, that depends on the cab being metal and so on. (If I had a dime for everything I don't know about trucks, I'd be rich!)
- [byuslim09]
you are hilarious doc'Doc wrote:I have doubts about the six foot thing being short enough to mount on the cab roof and not getting 'clipped' by bridges etc. But, if you think it'd clear them, that's where I'd put it. 'Course, that depends on the cab being metal and so on. (If I had a dime for everything I don't know about trucks, I'd be rich!)
- Hazelnut 7201
- Handle: hazelnut
- Real Name: Kerry
Doc is right about the 6' on top of the cab hitting bridges.
I drive a '06 IH daycab 9200 and anything over 65" starts to hit things.
How about those brackets designed to hold load bars? Can something like that be adapted for an antenna mount? Too bad you don't pull a flatbed and have one of those giant "headache racks".
Have a nice day.
Hazelnut
Hazelnut
- [byuslim09]
Hazelnut 7201 wrote:Doc is right about the 6' on top of the cab hitting bridges.
Good point hazel nut, I will stick with the mirror arm, appreciate all the help and ideas from the good time gang. ...bayou slim readn' the mail
