Not now
Get a better experience by installing our web app!
Hide
How to do it?
In Safari, tap on the menu bar. Scroll down the list of options, then tap Add to Home Screen.(If you don’t see Add to Home Screen, you can add it. Scroll down to the bottom of the list, tap Edit Actions, then tap Add to Home Screen.)
Connect with CB radio enthusiasts at CB Radio Talk Forum. Fuel your knowledge, unlock secrets, and engage in discussions. Join a vibrant community of like-minded individuals and explore the exciting realm of CB radios.
I am new to this police scanning thing!
I would like to know which handheld scanner (I am in Saint John New Brunswick Canada) to buy under $150.
.Best scanner and best value for my dollar (usb equipped)??MGHZ and trunk?
I look forward to your response
Thanks!
Information for your area seems limited, but it doesn't appear they use a trunked radio system. It appears to be a conventional 800MHz system. If that is the case, then a Uniden BC95XLT may work for you. It runs about $109 U.S. from Scanner Master. However, if I may, I would recommend the BC246T. It runs $209 U.S. but the added price will allow you to monitor trunked systems if there are any in your area. And, since a lot of areas do use trunked systems, you'll be able to hear a lot more when you go on a trip somewhere.
Yaesu FT-950
Yaesu FT-8100
Uniden Washington Base
Uniden HR-2510
Icom ID-92 HT
SteppIR 40-6M Yagi
OCF 75/80M dipole
Antron 99
