PREDATOR 10K
- Doobie
- Real Name: Jay
- Radio: Magnum S680
PREDATOR 10K
Anyone have an idea of what kind of mount I should use on this antenna and a good place to mount on 2009 Peterbilt?
Doobie
- The-Deuce
- Doobie
- Real Name: Jay
388 model. It's not the extended hood and not the short slanted hood. It has a slight slant to it. It's a winch truck with a metal headache rack.
Doobie
- The-Deuce
You can get the wide style mirror bracket mounts at most truck stops. That is what I had to use on my truck. Be careful not to over tighten the mount as it could bend or crack. I run a 10k as well and have it mounted on the drivers side, this way I can keep an eye on it. Opening and closing the door as had no effect on the antenna or my swr. I also use the predator stud mount. hope this helps.
Direct connection!
Remember," it was the Deuce".
- Doobie
- Real Name: Jay
I ordered the stud mount from Predator today. I had mounted on a regular stud and it looked kinda weak. I'm running a hustler until the Predator stud arrives. Thanks for the info. How much of the whip did you have to cut to get your SWR right?
Doobie
- The-Deuce
It was somewhere around two feet. It seemed like a lot but did the job.
Direct connection!
- minitrucker
i had too cut 3" off mine
- fatboy803
- Real Name: dwaine
Well....Yeah!...Daaaaaa......Problem is they are no longer being made, so pickin's are slim!fatboy803 wrote:The Predator 10 K supose to be a good antenna ?
That's an understatement. They are awesome.fatboy803 wrote:The Predator 10 K supose to be a good antenna ?
Mine gives an SWR check that would make you think the SWR needle is glued in place for all 40 regular channels.
It is also a beautiful peice of craftsmanship, and is very light in weight.
It receives so well that radio static now has a sucking sound to it.....
