Sirio antenna the Vector 4000 or the sirio 827?
- Nohandle552
- Super Mud-Duck
I was looking to buy a base antenna and was looking at the Vector 4000 or 827 antenna, but dont know which one is better? I see that some of you guys have one of these antenna. What would be the better buy?For DX etc.
- Texas Mobil 219
- Radio: Uniden 78
- Nohandle552
- Super Mud-Duck
- 26 TM 100
Of the two antennae you mention, the 827 is by far the better choice.
The Vector 4000 is a very effective antenna, but is of poor quality construction, and they have a tendancy to snap!
The 827 is of better quality, and will out perform the Antron as well.........I've tried all of these, and the 827 is the only one I would recommend.
If you do get the 827, it is worthwhile getting the anti vibration ring to fit on the groundplanes.....It does make a difference!
I agree. Although I've never personally used either, I have seen them up close and can confirm this. The quality of the Vector 4000 is very "thin" at best compared to the 827.26 TM 100 wrote:Of the two antennae you mention, the 827 is by far the better choice.
- silverstreak
- Handle: silver streak
- Real Name: Jon
- Radio: Galaxy,Ranger,Cobra
- 26 TM 100
- 1342
i have an imax which performs wonderful had a antron that was crap,runnin a maco 5/8 now this one is built very poorly and does not cover much of the band <<<<more crap.the vector has great reviews and would most likely out perform all the rest but would need some reenforcing maybe liquid foam or bamboo in the center or being tied off with heavy fishing line.there is a new sirio a vector 4000 upgade called the lw-150 this looks nice but is 31.2 feet tall wow!now thats a lot of antenna.the sweet spot is supposed to be 27 feet garys jpole claims 9db gain and is also around 27 feet.good luck to you!
- Loudmouth
I have the original Vector 4000 which is the only base antenna I have owned, so I don't have much to compare it to, but it performs extremely well. I am in a very low level area, and the base of the Vector is only about 27 feet above the ground, but it gets out very well and has great ears. I did have some trouble at first due to the screws that lock each section together rusted off and one section actually slid down into the other section, making the antenna about THREE FEET too short. Took me a while to figure out why my match was so far off all of a suddent. However, I rebuilt the entire antenna replacing every screw with slightly larger diameter, stainless steel screws, and loctited each one in place. I haven't had a problem since. My match is 1.0 on ch 40 and 1.1 on ch 1. It is a LOOONG antenna (31 + feet tall) and sways in high wind for sure, but since the rebuild it's held up to well over 50mph winds, freezing rain, snow, etc.. I think for the money (I paid about $130 as I recall) it's a great antenna.
Check back through my posts. I have a whole post on the Vector installation etc...
Good luck!
LM
Good luck!
LM
2010 Toyota Tacoma 4 Door TRD Off Road 4x4
http://www.***Censored***.com" onclick="window.open(this.href);return false; ... RULES!
It's a Super Whack Pack & Dave Made World!!
Everything else is just a toy!!
- Nohandle552
- Super Mud-Duck
- Nohandle552
- Super Mud-Duck
