What antenna should I get
- kralac
- Mud-Duck Jr.
I am pretty new to the whole CB sceen and am wanting to get a decent antenna that isn't very expensive. I have a 92' Jeep Cherokee and cant decide between a mag mount or a standard mount/antenna. I am using a Uniden CB. Any help would be appreciated.
- Gummybear
- Real Name: Samual
- Radio: 2-way baby monitor
The questions you need to ask yourself are: Is this going to be permanent or are you going to sell the vehicle or change your mind later?
How tall you want to be? How much money are you willing to part way with?
And how do the other members rate the antenna's in your price range.
If you want the best cheaper( not the cheapest, because you get what you pay for) and height is not problem, then the 102" whip or 108" ( whatever size it is...) is the best relatively cheap antenna compared to 10K's, monkey mades, etc.
I personally run a 5 foot 5 inch FRANCIS antenna and love it. But I am waiting for a predator 10K to arrive via UPS any moment....
The francis is super cheap, less than 20 dollars. They are NOT rated for high power i.e. Amps. but I have run a two pill into one with no problems, but its not recommended.
- kralac
- Mud-Duck Jr.
- treetall
- Handle: treetall
- Real Name: Carrington
- Radio: Galaxy
- Gummybear
- Real Name: Samual
- Gummybear
- Real Name: Samual
- kralac
- Mud-Duck Jr.
I think I'm gonna go with a 102, I checked and I can get one at a local place called Kodiaks for 22 bucks, and Ill grab a spring to, but I'm gonna get a mount for the roof of my Jeep, since its probably the best ground plane. I am wondering if I could get a mount that would attach to my cargo bars, or does it have to be attached to my roof itself for grounding purposes?
- Gummybear
- Real Name: Samual
- Irondog
- Real Name: Rick Haven
- Antenna: Dipole
- Radio: Cobra 142GTL, 949DX
- snipe 264
- Bolt cutter
Just make sure to get a good spring. Real stiff. I take down my 10K and run a whip when Im in the woods. I am higher with the 102 on my 10K mount so it does hit more than if I just had it mounted to the bed. But a good stiff spring I think is a must.kralac wrote:I think I'm gonna go with a 102, I checked and I can get one at a local place called Kodiaks for 22 bucks, and Ill grab a spring to, but I'm gonna get a mount for the roof of my Jeep, since its probably the best ground plane. I am wondering if I could get a mount that would attach to my cargo bars, or does it have to be attached to my roof itself for grounding purposes?
Let's do some WATTS!
- COPENHAGEN
102 inch whip all the way
Unit 306 from the back woods of north east Georgia JUST GOT DOWN
- treetall
- Handle: treetall
- Radio: Galaxy
- DUMMYLOAD
- Radio: MAGNUM, RCI, FATBOY
- tvfcsmokeeater
Watchdawg...to get the best SWRs across the band, the middle of the roof would be the G spot.watchdawg wrote:i really want a 102" but i just havent gotten to the radio shack to get one how well did you get it to tune
Kralac...I have a 96 Cherokee and have mine on a ball mount on the right side back by the tail light, right where the pocket is inside. I got ears,that's fer sure,but also contacting DRDX when i get the money to get a custom mag mount made
the smokeeaters back quiet
- Texas Mobil 219
- Radio: Uniden 78
What He Said. And they are tunable. Got mine on a few weeks ago. Tuned it and jumped 2 lb on the locals. Man they were impressed.DUMMYLOAD wrote:108" whip Is the way to go...you can get rid of that spring that rusts out...
Load
219 Swinging on 108'' in Texas
