honest opinion on monkey mades
- puller
- Handle: sledpuller
- Real Name: Toby Kappus
- Call Sign: KD2AFV
- Radio: Anan 7000DLE MKII
ok so i got a killer deal on a monkey made MM-5, now for right now i just want an antenna that'll work good. now i know everyone keeps saying the pred 10k is king, but for the deal i got on this monkey made i had to go for it. are the monkey mades really all that different? i mean would i notice that much of a difference between a 10k and a MM-5?
#403 the man they call SLEDPULLER waving from the garden state
As far as weight of the antenna itself goes, the MM is heavier than the 10K.
As far as performance goes, it varies from setup to setup but I know a few people who have tried a 10K and tested it out then tried a MM and the MM had better RX and TX in their particular setup. I have heard more stories of people switching from MM to 10K's than vice versa though. The only way you'll ever really know is to get one of each and test em. The MM isn't a loser by any means though so if you got a good deal on it, then go with it.
- backwoods
- Texas Mobil 219
- Radio: Uniden 78
- puller
- Call Sign: KD2AFV
Check out Hank Breedloves Machine Shop...These Mounts will hold the heaviest of antenna'spuller wrote:so what would be a strong stud mount? i planned on building a riser for the bed of my truck, right behind the cab
