honest opinion on monkey mades
puller
Handle: sledpuller
Real Name: Toby Kappus
Call Sign: KD2AFV
Radio: Anan 7000DLE MKII
#216840
Post by puller »
ok so i got a killer deal on a monkey made MM-5, now for right now i just want an antenna that'll work good. now i know everyone keeps saying the pred 10k is king, but for the deal i got on this monkey made i had to go for it. are the monkey mades really all that different? i mean would i notice that much of a difference between a 10k and a MM-5?
#403 the man they call SLEDPULLER waving from the garden state
Rex_foxhound
#216846
Post by Rex_foxhound »
As far as weight of the antenna itself goes, the MM is heavier than the 10K.
As far as performance goes, it varies from setup to setup but I know a few people who have tried a 10K and tested it out then tried a MM and the MM had better RX and TX in their particular setup. I have heard more stories of people switching from MM to 10K's than vice versa though. The only way you'll ever really know is to get one of each and test em. The MM isn't a loser by any means though so if you got a good deal on it, then go with it. :)
backwoods
Post by backwoods »
Yea! What he said!! Only thing I have ever been told bad is that MM's are heavy.
Popcorn501
#216853
Post by Popcorn501 »
That is there only down fall is that they are very heavy and you better have a super heavy duty mount or you will be breaking mounts!!!
Texas Mobil 219
Radio: Uniden 78
#216854
Post by Texas Mobil 219 »
MM are a good antenna. Preditors are great antenna's. If your not afraid to slap some things around. MFJ-1966, 108'' antenna if the way to go IMO. BUt its like everyone else has said in this thread. Different antenna will act different on vereus set ups.
219
puller
Handle: sledpuller
Call Sign: KD2AFV
Post by puller »
so what would be a strong stud mount? i planned on building a riser for the bed of my truck, right behind the cab
the_junkie
#216862
Post by the_junkie »
the monkeymades are a decent antenna.
I would reccomend the 55-r4 myself. I HAVE seen the light.
puller wrote:so what would be a strong stud mount? i planned on building a riser for the bed of my truck, right behind the cab
Check out Hank Breedloves Machine Shop...These Mounts will hold the heaviest of antenna's
Popcorn501
#216893
That is the type of mount i run now and run back in the day when i had two monkey made antenna on my truck,the brass straight mount
