beams
lonesome 500
#215124
Post by lonesome 500 »
sirio 4 element.....lightest....easiest to assemble.....best bang for buck......140.00
<center>
<a><img></a>
</center>
lonesome 500
#215134
you have a pm....
but...you are going to have to step up....running an 8 pill?
may have to go maco and buy bigger gammas........then the $$ come in
sirio specs...says 3kw max
Features: • CB Base station antennas !!< • Directional, High-gain • Horizontal polarization • Factory tuned at mid-band • High power handling capability • Elements equipped with waterproof jointing sleeve • Made of aluminium alloy 6063 T-832 Electrical Data • Type: SY 27-3: 3 element Yagi antenna • Frequency range: 26-28 MHz • Impedance: 50 Ohm unbalanced • Radiation (H-plane): directional • Polarization: horizontal • • Max. power: 1000 Watts (CW) continuous 3000 Watts (CW) short time • Feed system / position: Gamma match
<center>
<a><img></a>
</center>
CamoRedneck
#215146
Post by CamoRedneck »
Maco 103 or a PDL II
