wich one is better
- lonewolf1971
wich one is better
i have a wilson 1000 on my trunk. fake convertible keeps me off the roof. i am thinking of changing it to either a 102/108 steel whip or the predator 10k. what do you guys think would be the best to go with?
- Turbo-T
- Antenna: Super Big Stick
- Radio: Uniden Washington
- Goldhawk
- Real Name: Brian
- Radio: Galaxy
jessejamesdallas Verified
[quote="Grump"]The only way I would replace it is if the coil on the antenna is lower than the roof line.[/quot]
If you do that, then you may as well just get one of those stick-on window antenna's...Because having the coil below the roof line, you wouldn't be getting out across the street!
10k would have my vote. Although I'm a fan of the 102" whip, on some cars it just doesn't "look" right. I don't have a 10k (yet) but based on all the feed back I've seen over the years it either comes close to or exceeds the performance of a 102" SS whip (depending on the installation I'm sure). And without question, the 102" SS whip out performs the Wilson 1k/2k series...even the trucker. So if more performance is what you are after, that is a step in the right direction IMO.
Good luck.
Good luck.
