JesseJames...what's the truth?
the_junkie
#212010
Post by the_junkie »
I had someone try to tell me that 10k single antennas are true 1/2 wave antenans?
I don't buy it. what's the word?
backwoods
Post by backwoods »
They tried to tell you, no luck. My 27in shaft 10K is long but not quite 18 feet!!
Handle: Jesse James Dallas
Real Name: Jesse
Radio: working
Post by jessejamesdallas »
Predator 10K's are a "Coiled" antenna...they are electricaly equal to a 108" Whip (1/4 wave)...For as that go's...so is a Wilson 5000, 102" Whip with a spring, Monkey Made, 55's, and the stick-on window cell-phone look-a-like CB antenna.... :lol:
Last edited by jessejamesdallas on January 13th, 2009, 8:11 pm, edited 1 time in total.
lonesome 500
#212017
Post by lonesome 500 »
straighten out the coil....then measure
it's close to 1/4
<center>
<a><img></a>
</center>
HI-TECH
#212031
Post by HI-TECH »
lol not mine.. mine is single coil with a 12" shaft is longer then a 102" wip..
fireball894
Real Name: George
Radio: Cobra 2000
Post by fireball894 »
coils load the antenna by induction, providing the appropriate impedance where the antenna is fed...... it's not merely the extra length needed to make 1/4 wave wrapped up.....
Channel 32, or sometimes 33 and or 34......
coondog
#212039
Post by coondog »
lonesome 500 wrote:straighten out the coil....then measure
it's close to 1/4
:lol:
linx
#212045
Post by linx »
Someone told ya wrong, lol. It's barely 1/4 wave, let alone 1/2 wave.
Hey, there's a person locally that drives an old Chevy Beretta with a Antron 99 on the receiver hitch on the back...there's ya a half wave.
drdx
Handle: dollar-98
Real Name: David
Antenna: Many
Radio: Many-
Post by drdx »
If you stretched out a 10k it might be closer to a half wave than a quarter wave, but that's just because depending on the coil construction, the material in the coil has to be much longer physically than it would have to be in non coil form. Some coils contain twice the amount of length in conductor that you would need if you were running it in a straight line. However, it is the overall PHYSICAL length that will determine its performance in the real world. Well,that and several other factors, like coil placement, diameter, etc. Just to give you an idea, a half wave on this band is about 17 feet long, and even if it was a half wave tall from the mount up it wouldn't work in the feedpoint/swr department without some matching, as it needs to look like an odd multiple of a quarter wave to work, so it needs to look like 1/4 or 3/4 to work.
The truth? The 10k is less than a quarter wave, somewhere in the 1/5 category in the case of my single coil
the_junkie
#212054
jessejamesdallas wrote:Predator 10K's are a "Coiled" antenna...they are electricaly equal to a 108" Whip (1/4 wave)...For as that go's...so is a Wilson 5000, 102" Whip with a spring, Monkey Made, 55's, and the stick-on window cell-phone look-a-like CB antenna.... :lol:
Thanks Jesse, I didn't buy it, figured u would be able to tell me.
I thought something sounded funny lol
