Is it just the size of the wire coming off of the matching loop or is the v/58 base loaded and the v/5000 not? If its just the wire on the loop than putting a larger wire makes it a 5000 watt version same size tubing on the matching ring area
Special Insulator at the base and the wire that allows more power before it arcs over to ground ??? I don't know ,
I found this on 1 web site "This antenna has a Gamma match rated at 5000 watts" Looks the same to me ...Hummmmm larger wire same results?
I will be ordering a MACO V/58 just for the fun of it and disect it's base ...........and don't plan on running more than 1000 watts on 10 meters with it .
Someone said the 5000 version was better for lightning purposes on another website ........
