Help with Vanco SWR-1 use
akaCP
Mud-Duck Jr.
Mud-Duck Jr.
#211285
Post by akaCP »
First, I'm both a newbie to the CB world as well as CBRT. I've already found a good deal of valuable info here and I plan to stay around and learn more, but I've been unable to find an answer to my specific question.
I've just installed what will most likely be a temporary CB and a Wilson 5000 mag mount. The real question is on the use of the Vanco SWR-1. I borrowed it and there were no instructions, but found them on line. The problem is, the instructions are vague concerning the "calibrate" step. In understand the basic process, but with this SWR and it's instructions I'm confused.
This is what it says...
  • Set the center switch to "FWD" and rotate the adjusting knob to near minimum position (counter-clockwise)
Turn the transmitter on, rotate the adjusting knob for full meter swing.
OK, I'm lost. what is "near minimum position? what is "full meter swing"?
I'd post a pic of the meter, but forum rules and my newbie status does not allow me.
jegs
#211289
Post by jegs »
Set the switch to FWD and key the mic. Turn the knob until the needle is on SET. With the mic still keyed move the switch to FWD. That will be your SWR.
jegs
#211290
Post by jegs »
I screwed it up. Sorry.
Set the switch to FWD and key the mic. Turn the knob until the needle is on SET. With the mic still keyed move the switch to REF. That will be your SWR.
akaCP
Mud-Duck Jr.
Mud-Duck Jr.
#211291
Post by akaCP »
jegs wrote:I screwed it up. Sorry.
Got it, thanks. That's what I thought "set", but thank you for confirming. I'll give it a try.
Shotgun_228
Post by Shotgun_228 »
Those Vanco meters work really well I checked mine with a buddys MFJ analyzer it read the same in every situation.
Just my opinion.
Shotgun_228
djrebel236
#211329
Post by djrebel236 »
a oldie but still a good meter, i have two of them and they both still accurate and work great for all that i use them for...Dj
Night Crawler
Post by Night Crawler »
Shotgun_228 wrote:Those Vanco meters work really well I checked mine with a buddys MFJ analyzer it read the same in every situation.
The swr-1 also has a frequency range from 3.5-150mhz a good deal for the price.
akaCP
Mud-Duck Jr.
Mud-Duck Jr.
#211598
Post by akaCP »
Thanks for the feedback on the SWR-1. It's good to know that the tuning I'm doing is reliable. I wasn't sure of the meter's accuracy or reputation. I just borrowed it from one of the local radio install shops since they didn't have time to do it. Nice guy, allowed me to borrow it for the weekend.
Big_Kahuna
Handle: Big Kahuna
Real Name: Tim
Antenna: Wilson
Post by Big_Kahuna »
Must hang out with the guy a lot for him to lend his tools to ya. Sometimes that works out best and you don't have to go by all them meters and stuff. :!:
