TICKDOG wrote:thanks grump...I'm gonna try a 3/4 wave and see...if it won't work I can trim to a 1/4
let me know how it works then I'll try
Wile, you can try it. idk if it will work, but give it a tryI have a question for you or anyone else. What would happen if you were to run two radials and two ground planes on the same connector?
Lucky 7, im glad to hear that. havent got a chance to make contacts yet bc its kinda cold up hereHey Grump, I was bored yesterday so I also built one. It is working Great. I have it hanging outside from the second floor deck of my house. I was making contact's last night about as well as my mobile does if not just a little better.
Wile E. Coyote wrote:I got to make one of these antenna's the other day for my brother-in-law and got the swrs down to 1.3. He did have a couple of old Bull Dog Deisle antenna's stuck on the top of a mobile home and could not tx or rx worth a darn. Put this antenna on the front of the mobile home and he was able to tx an rx about 25 miles. I talked to him for that long at least in my mobile. He is happy that he was able to benefit from this short video and it didn't cost him an arm and a leg for a big antenna. One thing though, it is pretty much directional. I am going to try this at my house hopefully this weekend and see if I can manage to make it with two sets of radials. I will post my results if it all comes together right. I know that each radial will have to be tuned seperately.
Thanks, this was a great little project and only took less than one hour to make and set up.
Danny Rogers...........Wile E. Coyote................Unit 505 Land of Enchantment, New Mexico
Hey 654,4600 Turbo wrote:Wile E. Coyote wrote:I got to make one of these antenna's the other day for my brother-in-law and got the swrs down to 1.3. He did have a couple of old Bull Dog Deisle antenna's stuck on the top of a mobile home and could not tx or rx worth a darn. Put this antenna on the front of the mobile home and he was able to tx an rx about 25 miles. I talked to him for that long at least in my mobile. He is happy that he was able to benefit from this short video and it didn't cost him an arm and a leg for a big antenna. One thing though, it is pretty much directional. I am going to try this at my house hopefully this weekend and see if I can manage to make it with two sets of radials. I will post my results if it all comes together right. I know that each radial will have to be tuned seperately.
Hey Wile E. Coyote, 654 here. Albuquerque NM. I'm glad to see your going to put up a base atenna.
The dipole thingy won't work well if it done in a horizontal position for local talking. Everyone here runs verticals mostly.
You could set it up as an inverted V with an angle more than 90 degrees. to make it work like and omni. It's still alittle directional. It will have the bigger lobes of the side of the antenna. So put the side in the direction that you do most of your talking and it will probably work just fine.
I used to have one made by Radiowavz, but I put up with less than the 90 degrees required to make Omni, and it didn't get out very far in the direction I wanted. I took it down before I really experimented with it, and put up an a99 instead.
I didn't see 216 on the forum. Ok 216 were are you.
Talk to you on the airwaves. Wile E.
654 (Frijole) out.
