RG-213U Coax
BobOstro61
RG-213U Coax
#206961
Post by BobOstro61 »
I just picked up a 36' length with the PL259's on it. This coax should be OK with an A-99? Yes, I'm an antenna dummy.
#206973
If it's long enough to reach from the antenna to the radio, it ought'a work just fine.
(if it's too short, it ain't gonna work too well)
linx
#207011
Post by linx »
That's great coax. As Doc said, if the length is good, then you're good. RG213 is one of my favorites.
pipsqueek
#207023
Post by pipsqueek »
I'm with Linx on this. Great stuff, high power capability and non-contaminating. This is a terrific feature as in concerns coax contaminating itself after long periods on an ion exchange basis. After years some coaxes will break down and the dielectric portion will take on minute elements of the outer braid and inner cu rendering a not so 50 ohm coax any longer.
The 213 while not impervious to this process (entropy effect....everything eventually turns to junk) will outlast most (unless the woodchuck chews through it....sigh).
Only in my one long run situation where I use a type of 9913, all my stuff 100' from the house is 213. Ahem....A-99 on the shed is fed with rg8x...60' run.
Pips
North Texas Mudduck
Post by North Texas Mudduck »
proud of you
at least you not running a antron 99 on a pvc pipe
with mini8 and running 500 to 900 watts thru it and he wonders why he kills his neigbors
BobOstro61
#207476
Thanks guys. I was just hoping that the coax wasn't supposed to be used for ham antennas only. Now all I need is to get rid of this -5 degrees outside and pump it up to 50 or 60 to melt the snow/ice on my roof!
Rex_foxhound
#207548
Post by Rex_foxhound »
Good luck Bob! I've heard the weather up that way has been rough. Good to see you back on here a little more frequently. :)
BobOstro61
#209657
The weather here finally got good enough for me to install the new coax. The temp went up to 40 and the winds went below 40 for a change. Got 'er installed, checked the SWR and it was FLAT as a pancake. My meter doesn't even move when I key up. Looks like I'm back in action!
linx
#209706
Post by linx »
Good deal Bob! Glad ya got her working again.
#209801
Uh oh, didn't think of that. It IS only for ham antennas! So I think you should bundle it all up and send it to me.
(that's not gonna work, is it? Oh well, I tried...)
