Problems still with 102
- Cain64
I now have dead on 3's on 1 and 40 for SWR. I have around 26ft of coax but am gonna cut it down to 21ft. all the coax is good checked it all, the mount is grounded to the frame, i am completely stumped on this one, maybe a stronger ground but idk, i could take some pictures and see if you guys can tell by looking. Any suggestions?
Catching The Skip And Spitting The Grizz
226 Got Them Ears On
- Secret Squirrel
- Handle: Secret Squirrel
- Real Name: Joseph Husk
- Antenna: Hustler HQ-27 Magnum
- Radio: Stryker 89MC in mobile
Tire carriers offer a very poor grounds for an antenna mount. There is no way to make it work well at that mounting point. If you do not have one on the mount the 102 inch whip needs the 6 inch spring to be the proper length for CB frequency.
Secret Squirrel
"Talking to the USA from my Archer Space Patrol walkie"
3.0 on all channels means you have a dead short somewhere...Since you said you tested the coax, and it was fine, then I would look at your mounting bracket or what you have it mounted on...Make sure your mount is not grounding out to whatever you have it mounted on...There should be a plastic spacer between the mount, and whatever it's attached to...
Pictures of the mount may help...
- Cain64
- Texas Mobil 219
- Radio: Uniden 78
- Cain64
- Texas Mobil 219
- Radio: Uniden 78
I must of been posting when you were.
Anyway. Take the spring and check the wire inside. Make sure that it is not broke or even fraid. If it doesn't look broke. Take it of and see what your rig does.. If your swrs are still high change you mount. It might be the plastic insulator inside has gone bad like i said in my last post.
I think you might be getting alot of kick back from you jeep. My oppenion whips are best at cab hight.
If you would like i can build ya a mount that will clamp on to your tire rack and get it up to where you want it. Just need pic and measurments.
219 in Texas.
219 in Texas.
Hard to tell...But there should be a plastic washer between that spring, and your mounting bracket...Sometimes there is also one on the bottom, where the coax connector connects to the stud, so that the coax connector does not touch the bracket. (depends on what stud your using, some have two plastic washers, and some just have one that is notched so it fits in the hole of the bracket)
If the spring or stud or coax connector is touching that bracket, then you will be grounding out the antenna...
Sometimes you can "over-tighten" the coax to the stud, and squash the plastic washer to the point the connector or stud is touching the bracket, and will cause it to ground-out...
Last edited by jessejamesdallas on December 30th, 2008, 7:36 pm, edited 1 time in total.
yeah...may not be. Just be sure the coax connector, stud, and spring are not touching that bracket "at all, anywhere"...You can test the antenna with a ohm meter to see if it's grounding out.
(I "edited" my earlier post)
- 385
- Handle: Step~Child
- Real Name: Tracy
- Antenna: imax 2000
- Radio: Almost too many
OK...Good. Least channel 40 is lower, so I doubt your problem is a ground short...Most-Likely what your problem is, is going to be reflect off the back of the jeep... The antenna is just too low, and too close to the body of the Jeep... Your going to have to figure out another place to put the antenna so it's higher, so most of the antenna is not right up next to the body of the Jeep...Cain64 wrote:ok, i wnet out and put a spacer made of rubber bewteen the stud and the bracket channel 1 still at 3 channel 40 1.5.
If you move the mount to the top of that tire rack, I'll bet you'll see the SWR drop quite a bit...
- Cain64
SWR higher on channel 1 means your antenna is too short. But, since you have a 102" Whip, and the spring, unless the antenna has been cut, it should be the right length...Thats why I said to try moving the mount so that more of the antenna is up away from the body of the Jeep...Problem almost has to be too much reflect.
Guys mounting antenna's on toolbox's in the back of pick-ups sometimes run into this, if their antenna is too close to the cab.
- Texas Mobil 219
- Radio: Uniden 78
It sure sounds like the insulator inside the mount itself has gone bad. Whips put a lot of stress on the part of the mount. Firestick make a good one. I sent a pm to ya of a mount. If you look in the center were the plastic is. it looks okay and tests okay. But it isn't. I broke somewhere in the middle and short when i was keying up. Sent the swrs above 3. That might be your problem. Just get a new one and swap them out and see what happens.
What JJD said too. Kick back from the cab.
Good luck.
219 wave'n from Texas
Good luck.
- Ricky
- Real Name: Ricky F
- Antenna: coily, a99
- Radio: Magnum s9 Galaxy Bas
is there anywhere else you could try to mount that?
- TICKDOG
- Handle: TICKDOG
- Real Name: Chuck
