Problems still with 102
Cain64
#209227
Post by Cain64 »
I now have dead on 3's on 1 and 40 for SWR. I have around 26ft of coax but am gonna cut it down to 21ft. all the coax is good checked it all, the mount is grounded to the frame, i am completely stumped on this one, maybe a stronger ground but idk, i could take some pictures and see if you guys can tell by looking. Any suggestions?
Catching The Skip And Spitting The Grizz
226 Got Them Ears On
Secret Squirrel
Handle: Secret Squirrel
Real Name: Joseph Husk
Antenna: Hustler HQ-27 Magnum
Radio: Stryker 89MC in mobile
Post by Secret Squirrel »
Tire carriers offer a very poor grounds for an antenna mount. There is no way to make it work well at that mounting point. If you do not have one on the mount the 102 inch whip needs the 6 inch spring to be the proper length for CB frequency.
Secret Squirrel
"Talking to the USA from my Archer Space Patrol walkie"
Handle: Jesse James Dallas
Real Name: Jesse
Radio: working
Post by jessejamesdallas »
3.0 on all channels means you have a dead short somewhere...Since you said you tested the coax, and it was fine, then I would look at your mounting bracket or what you have it mounted on...Make sure your mount is not grounding out to whatever you have it mounted on...There should be a plastic spacer between the mount, and whatever it's attached to... :wink:
Pictures of the mount may help...
Cain64
#209241
Post by Cain64 »
ok well i will find a spacer let me get some pics give me a few minutes
Cain64
#209245
Post by Cain64 »
Texas Mobil 219
Radio: Uniden 78
#209249
Post by Texas Mobil 219 »
Sound like you might have a bad mount itself. Sometimes the inside of the mount will get cracked and cause a short. Had that happen to me. It looked good and tested fine.. I would short out on key ups.
good luck and waiting on pic.
219
Cain64
#209251
Post by Cain64 »
well im not shorting out theats for sure getting good reports from around 7 miles, so im beginning to guess my ground is not strong enough, ad or not completely on bare metal, the bumper is ground to the car so im not really sure.
Texas Mobil 219
Radio: Uniden 78
#209253
I must of been posting when you were.
Anyway. Take the spring and check the wire inside. Make sure that it is not broke or even fraid. If it doesn't look broke. Take it of and see what your rig does.. If your swrs are still high change you mount. It might be the plastic insulator inside has gone bad like i said in my last post.
I think you might be getting alot of kick back from you jeep. My oppenion whips are best at cab hight.
If you would like i can build ya a mount that will clamp on to your tire rack and get it up to where you want it. Just need pic and measurments.
219 in Texas.
Cain64
#209254
Post by Cain64 »
Everything is fine, im gonna try my ground again tomorrow.
Real Name: Jesse
Radio: working
Hard to tell...But there should be a plastic washer between that spring, and your mounting bracket...Sometimes there is also one on the bottom, where the coax connector connects to the stud, so that the coax connector does not touch the bracket. (depends on what stud your using, some have two plastic washers, and some just have one that is notched so it fits in the hole of the bracket)
If the spring or stud or coax connector is touching that bracket, then you will be grounding out the antenna...
Sometimes you can "over-tighten" the coax to the stud, and squash the plastic washer to the point the connector or stud is touching the bracket, and will cause it to ground-out...
Last edited by jessejamesdallas on December 30th, 2008, 7:36 pm, edited 1 time in total.
Cain64
#209262
Post by Cain64 »
there was never one on the bottom when i got it.
Real Name: Jesse
Radio: working
yeah...may not be. Just be sure the coax connector, stud, and spring are not touching that bracket "at all, anywhere"...You can test the antenna with a ohm meter to see if it's grounding out.
(I "edited" my earlier post)
Handle: Step~Child
Real Name: Tracy
Antenna: imax 2000
Radio: Almost too many
Post by 385 »
I had my 102 mounted on the front rail in the center right behind the cab on my pick-up and had high SWR problems also. Took it off and put my tool box on and mounted it on the back of the tool box in the center and no more SWR problems...1.2 across the band. Hope this helps, 385
Cain64
#209276
Post by Cain64 »
ok, i wnet out and put a spacer made of rubber bewteen the stud and the bracket channel 1 still at 3 channel 40 1.5.
Cain64
#209287
Post by Cain64 »
bump
Real Name: Jesse
Radio: working
Cain64 wrote:ok, i wnet out and put a spacer made of rubber bewteen the stud and the bracket channel 1 still at 3 channel 40 1.5.
OK...Good. Least channel 40 is lower, so I doubt your problem is a ground short...Most-Likely what your problem is, is going to be reflect off the back of the jeep... The antenna is just too low, and too close to the body of the Jeep... Your going to have to figure out another place to put the antenna so it's higher, so most of the antenna is not right up next to the body of the Jeep...
If you move the mount to the top of that tire rack, I'll bet you'll see the SWR drop quite a bit...
Cain64
#209289
Post by Cain64 »
ok, is there any way to move the antenna up but still keep the mount i have all thread spacers, or is the something you guys recommend. Does the higher on 1 mean its too long or too short,?
Real Name: Jesse
Radio: working
SWR higher on channel 1 means your antenna is too short. But, since you have a 102" Whip, and the spring, unless the antenna has been cut, it should be the right length...Thats why I said to try moving the mount so that more of the antenna is up away from the body of the Jeep...Problem almost has to be too much reflect.
Guys mounting antenna's on toolbox's in the back of pick-ups sometimes run into this, if their antenna is too close to the cab.
Cain64
#209292
Post by Cain64 »
ok well im gonna try something really quick just to see, im goona take a piece of all thread and put that on.
Texas Mobil 219
Radio: Uniden 78
#209293
It sure sounds like the insulator inside the mount itself has gone bad. Whips put a lot of stress on the part of the mount. Firestick make a good one. I sent a pm to ya of a mount. If you look in the center were the plastic is. it looks okay and tests okay. But it isn't. I broke somewhere in the middle and short when i was keying up. Sent the swrs above 3. That might be your problem. Just get a new one and swap them out and see what happens.
What JJD said too. Kick back from the cab.
Good luck.
219 wave'n from Texas
Ricky
Real Name: Ricky F
Antenna: coily, a99
Radio: Magnum s9 Galaxy Bas
Post by Ricky »
is there anywhere else you could try to mount that?
216 The Chally in the buckeye
73 from KD8MGF
TICKDOG
Handle: TICKDOG
Real Name: Chuck
Post by TICKDOG »
could be the proximity of the spare tire. looks like a couple inches max. maybe take the tire off and see if that isolates the problem.
unit "FIFTY~83"...Palatka,FL
Cain64
#209305
Post by Cain64 »
ok ill have to check all this tomorrow, i might go to a ball mount and put it up higher.
