Firestick
kenny kustom
Firestick
#206675
Post by kenny kustom »
I am looking at this mount for my Jeep.
How much power can you run through a firestick ? Could it handle a Magnum 357 ?
drdx
Handle: dollar-98
Real Name: David
Antenna: Many
Radio: Many-
Post by drdx »
It will handle a magnum. A firestik is good for what, 300 watts or something on the package?
That's not the best antenna out there, or the best mounting location, but the tj/wrangler is probably the hardest thing to mount an antenna on. For highway, jeep to jeep, and trail use it will work fine and have nice clearance, both important things to many. I like using windshield frame/pillar light mounts with a flat mount attached to one of those. It gets it higher and more in the clear, and is not on the corner of the vehicle so it is a little better about not being so directional. Either way, make sure you have a really good ground connection with some braid. The top of a spare tire carrier is also a nice location but again a little directional toward the front. -drdx
Kingpin1946
Mud-Duck Sr.
Mud-Duck Sr.
#206692
Post by Kingpin1946 »
drdx wrote:It will handle a magnum. A firestik is good for what, 300 watts or something on the package?
The doc has given you some sound advice.
TheTeZ
#206693
Post by TheTeZ »
i would try and mount it on th tire rack like suggested. The plastic licence frame seems a little scary to me, i dont know about you but i take my jimmy into some real tight areas, where i have only an inch or two of side to side play on the turn, and i know if my mounts were plastic i.... wouldent have them. i know the actual mount isnt plastic but what its connected to is.... also a corner's not too great of a location.
kenny kustom
I have a " no ground plane " firstick on the rear tire carrier now, but can get a decent swr reading out of it, plus, when i put my mag on the hood, and tried that, the power jumped and the swr droped. So id like to try something different.
TheTeZ
#206700
Post by TheTeZ »
SWR's probably high on the tire carrier because you need it higher, too much reflection or something..... maybe a longer antenna?
kenny kustom
This one here would gain me about 18" or so. I was just wondering about ground plane, with the fiberglass top.
kenny kustom
TheTeZ wrote:i would try and mount it on th tire rack like suggested. The plastic licence frame seems a little scary to me, i dont know about you but i take my jimmy into some real tight areas, where i have only an inch or two of side to side play on the turn, and i know if my mounts were plastic i.... wouldent have them. i know the actual mount isnt plastic but what its connected to is.... also a corner's not too great of a location.
The mount actually mounts to the quater panel.
TheTeZ
#206714
Post by TheTeZ »
ah, sorry.
and agreed \/ Go wilson silverload.
Porch Boy
Post by Porch Boy »
go with something other than firestik, them things aint got no ears. please believe it
kenny kustom
Porch Boy wrote:go with something other than firestik, them things aint got no ears. please believe it
Suggestions ? Keeping in mind, i do a decent amount of off roading.
How about this mount ?
Texas Mobil 219
Radio: Uniden 78
#206728
Post by Texas Mobil 219 »
Hey Kenny. I ran a 5'5'' firestick on my truck when i first got into cb's. Uniden 78 with a palamor 250 and i worked fine.
I true key here is you need to get the base of the antenna up to roof hight of a few inches higher. If you could get it up there your swr's should be around 1.1 to 1.3.
<-------<<< This is were my 102 '' is on my truck.
Good luck
219 quite in Texas.
kenny kustom
Texas Mobil 219 wrote:Hey Kenny. I ran a 5'5'' firestick on my truck when i first got into cb's. Uniden 78 with a palamor 250 and i worked fine.
Good luck
219 quite in Texas.
I would love to be able to do that, ( i had a wilson 1K on the roof of my ford ) but its just not practical in a jeep.
the_junkie
#206758
Post by the_junkie »
if this is any help--this is how gunny mounted his 102...
GUARD DOG
Super Mud-Duck
Super Mud-Duck
#206910
Post by GUARD DOG »
i would go with a wilson flex antenna
GUARD DOG
Super Mud-Duck
Super Mud-Duck
#206912
Post by GUARD DOG »
TheTeZ
#206942
Post by TheTeZ »
i was going to suggest the wilson Flex, because of the "flex" and the wilson performace, but i havent personally used one.
#207067
Post by 231 »
I'd run a Everhardt Tiger TSM-4' Superflex myself in a different location. Do you have a swing away rear tire carrier? I personally like the behind the tail light mount like TeraFlex makes. Had I known about them that's the way I would have gone...even though I have a SJF Tire Carrier. Although the behind the tail light grounding usually kinda' sucks, that can easily be fixed with added ground strap(s). Combined with an HD spring (which your looks like the medium to light duty), you'll be amazed at how much abuse they can take...especially in heavy foliage.
All my Jeepin' friends run them now, primarily because the work better than any of the Firestik and Wilson helical wound fiberglass (not to mention most all of them I've done comparisons). Do a quick disconnect and run whatever you want in seconds. That's what I do. I run my TSM-4' most all the time, but run my 102" SS whip, 5.5' Tiger SOTT, even my little base loaded antenna(s) when I want (or while running the hard top). I know on most of the Jeep forums they all boast of what a great antenna the Firestik is, but frankly I think they are horrible. Especially if you want to run an amp.
Here's my TJ with the 4' Superflex on it. I run an old SBE Sidebander or one of my old trusty Pro510's in it.
And here's one we installed on one of my wheelin' friends LoD bumper. I have a few friends that have done this very same set up without a problem, too. With a Firestik though, they are so heavy they don't flex much and simply don't perform as well. I can tell you several times I've heard and made contacts the others simply couldn't do...even with my Pro510!
And on another friend's CJ
There are all kinds of mounts you can do. And frankly, if you wheel your rig like we do, low foliage is always an issue. If you have the ability to switch things out easily, you can simply run whatever you want. I usually keep the TSM-3' also as a back up in the TJ just in case I break my 4' (or someone else does) but it hasn't happened yet.
Red Ryder
#207078
Post by Red Ryder »
Firestik is a fine antenna. i have 2 and ill tell ya i have BIG ears grandma!!!! and my swr is 1 always. i can shoot skip barefoot and hear em all over the usa just fine
