How to ground
Cain64
How to ground
#205731
Post by Cain64 »
I have a wilson 1 K and the connectore portion is no good so is left ia a good whip and good base, no mag or anythig. So i am not able to create any ground with this, how would i go about making a ground so i could use this as a base or as a mobile again on a stud?
the_junkie
#205741
Post by the_junkie »
i wouldn't use it personally-if the coils are bad inside, you are not gonna have a true 1/4 wave, and you'll never get the thing to tune up
Cain64
#205751
Post by Cain64 »
The coils inside are good the base and whip are fine but the mag mount piece that screws in is no good, but the actually antenna with the base load are in perfect condition.
#205880
It sounds like all you really need is the right 'connector' for the antenna to fit on. some manufacturers use a really proprietary type thingy and you'd have to get one from them. Other manufacturers use a sort of 'tandard' type of whatever connector it is. No idea which you may have, good luck.
Cain64
#205959
Post by Cain64 »
ok, the problem is i dont know how im supposed to ground it.
Cain64
#205987
Post by Cain64 »
Bump
IRON HORSE 128
Handle: johnny quest
Real Name: john fava
Antenna: davemade
Radio: rci 2970n4
Post by IRON HORSE 128 »
They do sell replacement bases. I have replaced my magnet mount several times.
