cobra 29 final
Lunchbucket67
cobra 29 final
#18380
Post by Lunchbucket67 »
Ive run the same Cobra 29 for 11 years in a Peterbilt and never had a problem with it. I am getting a new truck and decided to get a new cobra 29. Anyhow, I also have a 29 a friend gave that will receive but wont transmit. Ive always wanted to try to work on radios. Is putting in a new final going to be hard for an amateur to do?
BigBopper
#18381
Post by BigBopper »
If you can solder you can do it, you need some heat paste, sometimes the final screw is glued a little, but easy to do, attached is a pic that shows you where the final is
Phaze91460
#18387
Post by Phaze91460 »
Dang, yer awsome big bopper, do you have a library on radio pix ?
Lunchbucket67
#18474
Thanks dudes
