CB Mount
BobOstro61
CB Mount
#15961
Post by BobOstro61 »
I need some ideas for mounting my CB in my 2003 Ford Ranger. I made a little mount for it (if you've seen the pictures) and it just isn't doing the job. It tends to want to fall over if I make a sharp turn. I am looking for something in the way of a hump mount since there isn't any room under the dashboard to mount it. There isn't any carpeting on the floor. It has that plastic flooring instead so those saw-tooth mounts wouldn't work. Other than that, it may be back out into the garage to put my amateur woodworking skills back to work!
BigBopper
#15964
Post by BigBopper »
Kriket Kamel radio mount, old school hump mount, Kritet made the best radio speakers for years, I guess they went out of business'''see more pics here
BobOstro61
#15965
It looks like you have to bolt that one to the floor. I'd have to drop my transmission just to get the nut on to the bolt from the looks of it.
Then again, there's alway velcro!
BigBopper
#15966
Post by BigBopper »
Not it sits on the hump, I guess you could bolt it to the floor, or put velcro on the floor and mount,,,LOL, never thought about bolting it
Phaze91460
#15982
Post by Phaze91460 »
Go to wall mart or home depot and get that rubber mesh no slip material and install it under that hump mount and it wont slip off the rubber floor mat unless you are cornering way too hard. I use it to keep my laptot on its mount and it works.
BobOstro61
#15986
Good idea! I didn't think of that stuff.
Guest
#15991
Post by Guest »
WHY BOLT IT JUST GET SELF TAPING SCREWS TO HOLD IT TO THE FLOOR
Phaze91460
#15992
Self tapping screws will work but will mess up that matt if he wants to do something different in the future .
Guest
#15994
Post by Guest »
SO WILL BOLTING IT TO THE FLOOR WITH THE SELF TAPERS HE WILL NOT HAVE A BIG HOLE FOR THE BOLTS GO THROUGH
#15997
Post by 231 »
THUMPER wrote:WHY BOLT IT JUST GET SELF TAPING SCREWS TO HOLD IT TO THE FLOOR
Ditto that. I lagged screwed a couple sizable strut "L" brackets into my Dodge on the hump, using extension brackets to move the radio bracket where I want it. It's very easily accessed when driving and quite frankly not noticable when removed (which I've done). Nothing more distracting than watching everything shift on a corner or slamming on the brakes. I don't worry about that anymore.
Lots of stuff you can do though. Sorry, I haven't seen your specific set up...but I think much of it depends on how much channel surfing you do. I do lots...so like the radio very accessible.
5H Outlaw
#16012
Post by 5H Outlaw »
Hey Bob, just an idea but check my persoal gallery. I used checker plate and attached it to the center console mounting bolts. Might work for you?
Guest
#16061
Post by Guest »
:Peace!: Sounds good!
Falkon MX-5
#16068
Post by Falkon MX-5 »
I used velcro and actually velcroed one radio behind my seats to the carpet. with this one, I used the bracket and attached it to the underside of the dash.
Okay, I have done autocross and pulled well over a peak G with this radio in the car, and it has not acted like it's going to fall off in any way.I assure the bracket that comes with the radio can take whatever you can dish out so long as you mount it correctly.
BigBopper
#16071
Post by BigBopper »
Mounted mine next to the passenger bucket seat in the mini van
Guest
#16073
Post by Guest »
:coolio:
BobOstro61
#16090
In a perfect world, I need my mount to be portable. Then I can move the radio from the mobile into the house so I can use it as my base as well. Something so I don't have to unscrew the radio from the bracket. I want to just lift the whole thing up and bring it in.
Guest
#16095
Post by Guest »
HELL!Just mount your radio bracket and unscrew the radio from the bracket!No big deal! :lmao: It ain't going to hurt your truck! :Peace!:
LordDragr
#16183
Post by LordDragr »
i have a 2000 ranger and had noproblem monting mine under the dash. If I could see the inside layout for the 03 model I might be able to come up with a suggestion.
Peddler
#16271
Post by Peddler »
I don't know if your trk has a factory installed little plastic cup holder/console or not. My 98 did and I removed it and put in place the 1X to attach everything to. I used the same mount holes as the factory.
Guest
#16289
Post by Guest »
:Peace!:
Little Reb
#16295
Post by Little Reb »
Found a picture of a 2003 4x4 5spd worse possible situation to mount a radio i would say. im sure on of yall can find a place to mount it in that
LordDragr
#16303
Post by LordDragr »
bob what are the size dimenions of your radio?
DIRTBOY
#16304
Post by DIRTBOY »
I cut up and bent a piece of aluminum that goes in front of the middle seat. The mounting holes are slotted so it fits between the bottom of the seat and the seat mount. The bolts that hold the seat down pinch it between the seat cushion and framework. With the slotted holes, I can loosen the bolts and slide it right out. Hope this helps. I know there are a few Dodge guys doing this.
DAYDREAMER
#16318
Post by DAYDREAMER »
I used a couple of short lag screws, garage door hinge screws, to bolt a "U" bracket made from flat stock to the tranny hump through the carpet. It's held well for the last 2-3 years.
