Help Needed: Bad Crystal in Tram D201A
Jester
#148023
Post by Jester »
Hi Folks,
The other night, a good radio friend of mine and I were trying to troubleshoot the fact that several channels on the radio had no rcv or xmit...After reviewing the situation, it appears that a 4.410 mHz crystal has gone bad which controls channels 2,6,10,14,18,22,27,32, and 37. Does anyone know where I can get one? My friend said he would help install it providing I can find it...any ideas? Thanks!
garyo
Super Mud-Duck
Super Mud-Duck
#148028
Post by garyo »
drdx
Handle: dollar-98
Real Name: David
Antenna: Many
Radio: Many-
Post by drdx »
Find out of JAN crystals is still in business. Search the web. If you don't find one, or them, I can check with an old school local shop here that has a healthy radio graveyard. -drdx
Popcorn501
#148056
Post by Popcorn501 »
Look up Greg Barkett at Barkett Electronics he is the guru on trams and brownings
Jester
#148869
Post by Jester »
Gentlemen,
So far I have emailed JAN in Florida but they haven't answered yet...it's still early though...Greg at Barkett is kinda far away, and the 1st link you guys sent me has the crystal for 14.99, with a 20$ minimum. Thats not so bad.
My only concern is getting a soldering iron that is grounded as I dont want to blow any FETs on or near the crystal card, that would be lame...
TwentyTwo-Zero
#148882
Post by TwentyTwo-Zero »
Hi Jester,
As long as the soldering iron you use has the third ground prong on the plug you will be okay. These type of soldering irons are grounded. Good luck with your project... :wink:
Forgot to mention: The soldering iron must be plugged into a three prong (grounded) outlet - don't use an adapter to plug it into a two prong outlet or you will be defeating the ground unless the adapter ground tab is secured under the screw that holds the outlet cover on...
Save Your Money, Don't Go To The Show
And Don't You Eat That Yellow Snow...Frank Zappa
WR0220 Washington State 38LSB
CPI • Cobra • Icom • Yaesu
Jester
#148909
Post by Jester »
22-0,
Unfortunately, all I have are Weller and/or Radio Shack cheap-o's that are maybe 40 watts at best. I was thinking of unplugging the desoldering iron when it gets hot to melt the solder to get the crystal out, and do the same thing with a 2-prong pencil soldering iron. Would this prevent any damage to the FETs on board? Just an idea....
Otherwise, I am thinking grounded soldering irons may be expensive...But they sound like a necessity...
TwentyTwo-Zero
#148912
You might get away with using the desolder iron, but (if it's the one Rat Shack sells) I'd be careful with it since it's 45 watts. If you don't mind adding another iron to the collection, the Rat Shack 64-2051 is a grounded tip 15 watter that runs about $9
4 cycle
Handle: 4 CYCLE
Real Name: JOSEPH
Radio: MESSENGER 223
Post by 4 cycle »
KENS ELECTRONICS!!
rev ike
Post by rev ike »
Jester wrote:Hi Folks,
Just in case you are unaware :the channel selector also goes bad on these models and makes the crystals appear bad ,I have a question can you tx& rx on the VFO side of this radio? I have many questions but this post is a few days old I dont know if you got it fixed already.
MAY THE LIFE I LIVE SPEAK FOR ME!
Jester
#162868
Post by Jester »
I have been told about the channel selectors going bad, however it leads me to believe that the x101 crystal is out because the channels controlled by x101 are non-functional. I am going to bring the unit by a friends house this week (maybe today) to have him look it over, and we shall see...
warlock35po
Handle: Warlock35Po
Real Name: Don
Call Sign: VE1CSP
Antenna: Beam and/2 wave Dipole
Radio: Kenwood 570 D G
Post by warlock35po »
Hello Jasper,just wondering if you ever got the Tram fixed.I could be wrong but my D 201A crystals each one only controls I think 5 or six adjacent Chanel groups.I know this is an OLD post.Just curious.Regards,warlock35po
